noise from rear tire or pully
Old 07-29-2012 | 07:36 PM
fshrs1's Avatar
fshrs1
1st Gear
Default noise from rear tire or pully
'11 street glide, 15k miles. Ive noticed in the last couple thousand miles when cornering a noticeable whinning noise, louder with left turn than right, coming from the rear axle/tire/pully. Still under warranty, just looking for some feedback before I take it for service.
Old 07-29-2012 | 07:41 PM
RoadGlideGary's Avatar
RoadGlideGary
If it is under warranty take it in sooner than later. Sounds like a bearing.
Old 07-29-2012 | 08:02 PM
Gearhead3's Avatar
Gearhead3
Rear tire cupping?? Check for 'feathering' along the edge of the tire.
Old 07-29-2012 | 08:04 PM
TORQUEY's Avatar
TORQUEY
To me is sounds like a warped rotor.
Old 07-29-2012 | 08:12 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Misalignment of rear wheel. tire rubbing belt guard or swing arm
Old 07-29-2012 | 08:16 PM
EasternSP's Avatar
EasternSP
Veteran: Marine Corp
I would think its the tire. You have worn the center of the tire down and you can't hear the new tire noise anymore except when you lean it over onto the not so used tread.
Old 07-29-2012 | 08:34 PM
bsr8wtrod's Avatar
bsr8wtrod
+1 on the cupped tires. I have an 11 SG and it startrd making the same sound at 10,000 miles.
Old 07-29-2012 | 08:35 PM
ndnguyd's Avatar
ndnguyd
Tire......
Old 07-29-2012 | 08:57 PM
BigDawgQC's Avatar
BigDawgQC
Glad someone brought this up. My 09 RK does the exact same thing, louder on the left turn than right. I'll have it looked at.
Old 07-29-2012 | 09:38 PM
hockey8787's Avatar
hockey8787
Its the rear tire nothing wrong with it, just normal wear sounds, it will go away when you replace it!!
Quick Reply: noise from rear tire or pully
