yellow pipes
That's because your bike is set up with STOICH AFR. Thanks to the EPA. http://en.wikipedia.org/wiki/Air%E2%80%93fuel_ratio
Get the bike tuned, then get some Blue Job, I had a V Star and they don't have heat shields on the front header pipe, it turned yellow and blue, the blue job is a powder that with a little water turns to a paste and you simply rub it on the blue and yello pipe, it works great, nothing else I tried works as good as Blue Job.
I had a problem with bluing chrome a while back and used this stuff called "Blue Job" that got all the blue out of the chrome. It takes some serious work, but you can get the color back to fine chrome. Check that stuff out. Worked for me. http://www.blue-job.com/ Don't know how it would do with yellowing, but might be worth a try.
