ACC switch?
Same on my 09. Under the seat is a plug with 4 pins.....there is a square rubber capped plug. With the ignition switched on....probe each of those pins (one of the 4 is a ground) then flick the acc dash switch on and off. You will see one of those leads will go on and off with the switch. Thats your controlled acc switch lead.
The other lead is constant on and the third hot goes on and off with ignition if I recall correctly.
I stole this from Mike M this is the one he posted and this is the plug.
Shouldn't need any more tools than a phillips screwdriver.
Take off your seat.
It's probably tucked down in front of your battery, but there should be a gray, four pin Deutsch connector. Should look like this:
You can get a plug to fit for about $4 from Amazon, J&P Cycles, and a few other places.
I took my ECM off the top of the battery to better access the wires, but it really wasn't necessary.
Take off your seat.
I agree Mike...I have learned a lot from searching and just reading the new posts. My new SG is like learning everything all over again after owning an older carbed softail for quite a few years. Thanks to everyone here at HD Forums!
