I am sick/ bad news from the dealership
Old 07-27-2012, 09:24 AM
Bushy's Avatar
Bushy
Bushy is offline
the HD adjuster will have to come and see for final say, Its all covered and the Dealer has to answer to HD .. The support structure is intact, I have been where you are and it worked out fine
Old 07-27-2012, 10:19 AM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
Mechanical machinery, it is what it is. At least you are covered under warranty, maybe you bought an extended warranty?
Old 07-27-2012, 11:20 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
Originally Posted by HDJIM1158
Yeah, starting to feel that way also
Thats where I am also.......
Old 07-27-2012, 01:17 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
Whoa a minute-- they said it could be a lifter OR a flywheel? There's a long way between the 2.
A typical symptom like yours indicates a lifter as a more likely cause.
I've never heard a flywheel click....
Anyway reads like your covered which is the main thing.
Old 07-27-2012, 04:21 PM
HDJIM1158's Avatar
HDJIM1158
HDJIM1158 is offline
You are very correct, part that is really pissing me off is they have it for 2 days and the SOB's still haven't said what the problem is. I understand it can take awhile to get it back but answers should come much faster. I always stood behind this dealership, but I am not very happy now. Time will tell if they will get more of my money.
Old 07-27-2012, 04:29 PM
Arizona's Avatar
Arizona
Arizona is offline
No worries, it will be fine when they're done. These things happen now n then.
Old 07-27-2012, 04:34 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
Sounds like a lifter from what you're describing, did the mechanic use a scope to listen and see where the noise is coming from? At least you have a warranty, I really wouldn't stress over it if I were you.
Old 07-27-2012, 05:03 PM
MADHOG's Avatar
MADHOG
MADHOG is offline
Originally Posted by Weavr99FLHT
I put 70,000 miles on a Harley that "click- click- click" on cold start up. Thought it was normal ;-)
+1. I've always looked at cold start up noises as normal. If it keeps up after the warm up I would start being concerned. I don't think I would trust them to start tearing stuff apart and trying to find the problem, when there may not be one. Once they start you just may end up with other problems. Oh well, your bike, your call...
Old 07-27-2012, 06:11 PM
dswansbiker's Avatar
dswansbiker
dswansbiker is offline
So you may have an issue with your bike that is covered under warranty and now your are "starting to question my support for Harley". This just baffles me. Would it make you feel better if they refused to fix it?
Old 07-27-2012, 06:30 PM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
Ditto and still going strong.
Quick Reply: I am sick/ bad news from the dealership
