Vance & hines fuel pak or harley tuner
I just bought at new 2012 Ultra classic. Wondering about exhaust headers, mufflers and a tuner. You guys already posted some thoughts on the exhaust. Considering either V&H Power Duals, or Dresser Duals. They say the power duals are better. Going to use Monster Ovals or 4" Rineharts with which ever header. Dealer wants to sell me a turner. I just want it to run good and not really wanting to pay to have it dynoed. So thought about V&H fuel pak. Seems pretty simple. Also adding V&H stage one air cleaner.Thoughts please.
Thanks
Thanks
I have the V&H True duels, Monster ovals with the V&H Fuel Pak. After 47,000 miles and no problems with this setup I feel comfortable in recommending. I consistently get 36/40 mpg, no popping or other problems. It is an inexpensive way to achieve fairly reasonable results without braking the bank. It has worked for me.
Thanks
Thanks
I have Vance and Hines Dresser Duals and Rinehart 4"s and I opted for the Power Vision with a Fuel Moto map. For $500 you get soooooooooooo much technology in the Power Vision and the fact that Jaime from Fuel Moto is a dyno master and the fact that you get life time map support.....how could you go wrong?
As for the headers/head pipe, you can't beat the sound of true duals....with almost andy slip-ons. I bought Rineharts like 4 months ago.....I heard a set of CFRs and I want to swap!
I used a Fuelpak with a similar setup. It can be adjusted, but only with codes from V&H. I didn't like the way the double sided connector fit with the ECM. I suggest a PC V. They are easy to install, easy to adjust, and fit under the seat better. Order it from Fuel Moto and they will ship it with the map you need on it.
IronStu
08-01-2015 12:51 PM
