satellite radio
RE: satellite radio
You have to watch on some radio's, they make a special hard wire hook up. I have the Roady and there is a step down in voltage built into the cig plug, the radio does not operate on 12V. I installed another cig plug under my fairing and pluged the radio in there. Then I ran a bead of clear silicon around the plug so it would not vibrate loose or out. Tapped into the cig plug inside the fairing for power.On your Road King you can also get the adapter to hook up to the plug under the seat for Aux. power, it come as a wire or with cig plug on the end. If you hard wire right off your battery it then also be used as a place to plug in a battery tender, just put a plug for a cig on the tender, also a place to charge a cell phone.
Clap
Clap
RE: satellite radio
No, no, no.
First go to WalMart and get one of the ciggarett outlets with the spring loaded cover. Mount it pointing down by drilling and tapping a couple of holes in the frame gusset that is just forward and below the gas tank. Now reach up under the headlight and you will find a couple of wires (my '01 hads a pair in there. I don't know about yours). Connect to them.
Plop the antenna on top of the headlight and you're done.
When it starts to rain you can unplug everything in a few seconds.
I take pictures but it's 7 degrees and dark.
RE: satellite radio
This is an old thread from a few months ago, but I did a search and this was the only one I could find. I am in the process of hooking up the Sirius sportster receiver on my 03 Road King. I noticed at the HD dealership they sella cigar plug that is supposed to plug into the wire harness inside the headlight. I looked inside the headlight housing and noticed an orange plug and I assume this is where the cigar plug connects to.
There is an aux switch on the left side of the chrome housing opposite the highway light switch. I assume this powers the aux power hookup. Am I on track so far?
My question is: Is this the best way to hook all this up, or is there a cleaner way to do it so there aren't a whole lot of wires running all over the place.
Right now I already have external (amped) speakers on my bike and the power for those is routed straight to the fuse box. I use an iPod with my speakers on battery power. With the Sirius there isn't a volume control on the reciever is there? is there a model that has a volume control on it?
Looking for ideas, thanks.
