Monkey Bars Pullback question?
I am looking at getting a set of PYO Monkey Bars or some RSD bars etc...the dilemma I am having is that I have shorter arms. I find the stock bars need to come back about an inch or two.
1- What's the pullback like on the monkey bars? I know it lists the measurements on the website but what's the real life comparison to stock for pullback?
2- Can you rotate the bars back to create more pullback...and if so does anyone know if it can be close to stock or a bit more?
I've looked at other apes but really like the sharp angled look or the Monkey bars and RSD bars. Was also looking at the new adjustable Arlen Ness bars
Cheers,
Mickey
Cheers,
Mickey
I have the same question. I've been looking at the 10" Yaffe Bagger Bars. You can pull them back some. Just not sure how much. The limiting factor is the gas tank. I'm 5'7" and would like more height but also a couple inches back (more than stock). I'm inclined to give them a try. If they don't work out I will just sell them. It's a lot of effort if they don't work out though. Subscribed.
Same here. 5'7" w/29" inseam. Currently using HD reach bar, help some, but if I lean back on the adjustable seatback, I have to reach for the handle bar. Indy suggest a 10" or even 12" mini-ape and rotate it back so the hands are at or slightly below the fairing. But all mini-ape I found are too wide, than tight corner becomes a problem.
The closest I found on mini-ape widthwise is 34.5", which is still a full 2.5" wider than my current HD pull back.
That's a great idea. Thanks for the link. May be the way to go. Looks like they aren't currently taking custom orders though.
