Apes wiring WTF
Got my Wild1s 12 1/2s in today. Beautiful. Have any of you made up your own wiring? The prices for the kits have varied between 250$ from FBI to almost 400 from Yaffe. So I thought Id just buy the clutch cable and brake line from Harley and get the wires from ACE or Home Depot and splice em in myself.
Any electrical geniuses out there see any problems with doing this to the drive by wire? Or should I get the longer wire kit from HD? Some guidance from some of you guys who have wired em yourself would be appreciated.
Yes I did it all with a spool of 18 gauge wire. Soldered, shrink tubing etc. Also cut the green TBW plug out of the loop and hardwired it the same way. I watched a video on ape install by LAChoppers over and over till I got a good idea of what I had to do( youtube). A +6 on both the clutch and right MS brake line should be fine. Make sure your clutch slack is factory pull of 3 & 1/2".
I just ordered extended wires monday and it ran about $50.00. It was the cables which I bought from Magnum Shielding that ran me over $200.00.
Here's where I ordered my wires from. I hope it helps!
http://www.namzcustomcycleproducts.c...to_06.html#top
Did mine back this winter. Agreed, no need to buy the Yaffe kit. Wish I hadn't spent the money on it either. Get the brake lines from Magnum, and get the clucth cable from someone else too.If you're going with 10" bars, the stock clutch cable is fine. The one Yaffe sent me, was the exact same length as the stocker. No need to pay Yaffe's price on that stuff.
