Fairing vibration
I bought the brackets from Ragan Fab last night and installed... took about an hour to install all four. Problem solved !
My left upper bracket was broke at the mounting tab.
Very easy to install and they are machined perfectly to fit the OEM brackets.
http://www.nwmachine.com/rfw//Gallery.htm
The '07's were particularly bad about shake at idle, apparently a combination of the first-year 96" motor and the old motor-mount system. Newer bikes (not sure about '08) had a revised motor-mount system and are much smoother at idle.
The '07 is brutal on fairing brackets, especially if you've added heavier speakers, and I've been through probably three sets of horizontals in 55k miles. The right vertical broke and instead of replacing it I repaired it, also fortifying the left one. That was 32k miles ago and the fix is still intact even after an accident during that time period. I did a write-up here, and another one about adding a second horizontal bracket to fortify the area when using heavy aftermarket speakers.
There were no aftermarket fixes available at that time, but after looking at the Ragan kit I would probably recommend that instead of doing a fabrication like I did. OTOH it isn't rocket science and if you can use a hacksaw, drill, and bench grinder you can make a bracket to fortify or fix the verticals. The horizontals are another story and I couldn't figure out a way to fix/fortify those with my limited metalworking skills.
Yeah, the '08 had the same frame and I think motor mounts as well, but a different location of the turnbuckles. They addressed the jackhammer effect in '09 by changing the frame and mounts. There's a big difference between an '07 and '09 at idle.
mine started a vibration about 3 weeks ago. also the sound was not "usual". the vibration was not bad when accelerating but bad on decel along with the "sounds". after removing the oil cooler and Voltage REg. found that the support bracket had one bolt snapped off and the other loose along with the side stablizer bolt missing. the front mount was actually ok except for a crack that was starting underneath. I went ahead and replaced the rubber mount when i fixed it. it's the new one from HD and is a little more vibration that before. everything is good now...
