Rusty exhuast studs, how to remove and replace
Old 07-24-2012 | 03:04 PM
Coastiejosh's Avatar
Coastiejosh
Default Rusty exhuast studs, how to remove and replace
I'm putting on new exhaust this weekend and went ahead and removed the mufflers and headpipe. I noticed my headpipe nuts and studs where rusty at the cyclinder exhaust port. How do I remove the studs? Does anyone make stainless studs, and what is the thread pitch on the?
Thank You
Josh
Old 07-24-2012 | 03:14 PM
Neckball's Avatar
Neckball
Any time I've got the exhaust off I always replace the nuts, it's too easy for the hex to get rounded off and the nuts are cheap. Not sure I would worry about the studs, you may get into something you don't want to, they may not come out of the head very easy. I'd just clean up the threads and put on some new nuts. Nobody is really going to see it but you anyway.
Old 07-24-2012 | 03:17 PM
chuck3049's Avatar
chuck3049
He is right, just replace the nutts, the only time we replace the studs is if they break.
Old 07-24-2012 | 04:03 PM
honestbob's Avatar
honestbob
If you are worried about the rust, run a die-nut on them. I have never seen an exhaust stud over a month old that wasn't rusty.
Old 07-24-2012 | 04:15 PM
HalfFast's Avatar
HalfFast
After you clean them up, coat them with a high temp grease or copper anti seize and put the new nuts on.
Old 07-24-2012 | 05:59 PM
skratch's Avatar
skratch
the environment the studs are in is not very forgiving. you are not gonna be able to keep a stud looking 'new' for any length of time. i wouldn't replace them unless they break.
Old 10-24-2014 | 07:58 AM
ridehard5185's Avatar
ridehard5185
Stage IV
Default exhaust studs
I was replacing exhaust and nut on stud was crooked(my fault). anyway upon trying to remove nut the stud also came out. how do I put back in head?
thank you guys
Old 10-24-2014 | 08:41 AM
SafetyMan's Avatar
SafetyMan
Clean 'em and use hi-temp anti-seize.
Old 10-24-2014 | 08:49 AM
Uncle Larry's Avatar
Uncle Larry
A "thread chaser" is better suited than a die. The die will "re-cut" the threads. A thread chaser/restorer will clean up the existing threads without removing metal. A set like this one ( http://www.summitracing.com/parts/shc-952105/overview/ ) is/can be a real time saver when dealing with older fasteners.
Old 10-24-2014 | 08:51 AM
mupepe's Avatar
mupepe
thank you guys
You should probably start a new thread. Everyone is going to respond to the 2 year old thread instead of your question.
Quick Reply: Rusty exhuast studs, how to remove and replace
