Total newbie questions.....
Ok....so here goes. I'm looking for lots and lots of input....
I just purchased a used 02 Ultra Classic. This is my first venture into a touring bike, as my last bike was a Night Train.
The bike was shipped to me, so when I got it off the truck today I noticed several things that are a bit different than my Night Train, but they are technically the same engine(T/C 88)
My biggest issue is a pretty serious engine vibration problem at idle. As far as I know about this bike, it's totally stock. It also pops quite a bit when I let off the throttle. Not that this is a big problem for me, but wondering if it's affecting the engine at all. It just seems like it's starving for power....and I know it's there because the NT had it.
I plan on doing a Stage 1 upgrade right off the bat, and adding some new slip-ons to let this thing breathe easier. That should help a lot. What I'm concerned is about the vibration issues. The NT never had it....in fact, that bike was as stable as they came, until I got on it.
Bring on the knowledge....
Pop might be loose exhaust header and/or pipes.
How many miles on it? A tune up might be in order. Wires, plugs, etc.
I always change out the oils when I get a "New to me" machine. Just to know that all is fresh and it is whatever oil I like.
Vibration may simply be new motor mounts if the old ones are shot.
Pull off the side covers and seat to see if there are any after market electronics connected. You may want to go back to stock, if it is simply a matter of disconnecting wires to some plug in add-ons, and go from there.
Do the simple things first.
I do not know about the 88's. But one in a NT could be different than one in a bagger. The current Softails have a different engine from the Road King as the Softail have the smoother crank or cam because of the lack of isolating motor mounts. And the Softail engine is definately smoother. Perhaps there is a similar difference between the 88's.
well, a night train is the softail frame - and a different motor!
the softail bikes use the "B" motor, which has balancing shafts to quell vibrations- but those shafts are a parasitic power drain
the touring bikes use the "A" motor, which uses a rubber mounting system - the entire motor and tranny are on rubber "donuts".
these may be worn on an older bike.
BUT the touring motor does bob and weave at idle speeds- um, it's "part of the charm"- smooths out at higher revs.
do the stage 1 then see how it runs, the process of doing the stage 1 may cure any air leaks etc.
Mike
Mike
I once heard some of the HD plugs have something in them. An electronic part. I may be wrong here. And it may only be for later models. So, make sure the plugs you buy are exactly the same. For the difference in cost you may just want to use the HD plugs.
Then again, if you do a stage 1, 2, 3, 5, 12, 137, who knows... you may be buying plugs as part of it. In fact, if you are going to buy plugs, wires, air cleaner, and stuff you might consider the stage whatever as some parts may be different depending on what you do. No need on paying twice for the same parts.
Mike
Mike
"Good, good, good.... good vibrations!"
