Brake piston
Brake piston
I am telling you,every 30 minute job I do turns into a fiasco.All I wanted to do is change my front brake pads on my '08 Electra Glide Standard.the first side I did,one of the pistons wouldnt go back in to make room for the new pads.So I had to split the caliper,All my fluid drained out.No surprise there.I tried a C clamp first to get the piston back in,it wouldn't budge.I actually bent the T-handle on the clamp.So I put the rubber side of a hammer on the piston with the caliper on the bench It took allot of pressure to get it to go back.But it finally went back in.And as usual I am out of brake fluid so I have to wait until tomarrow for the HD shop to open.Do any of you think this piston is going to keep giving me trouble?Maybe I should pop it out completely and clean it really good.
