shifter linkage
Old 08-10-2012 | 03:35 AM
Stiggy's Avatar
Stiggy
Originally Posted by FLoTR
I fixed my rattle. no heim joints or any other parts. I took advice about disassembling the front shaft to clean and grease it. In doing so, i found the inner lever bolt was not loose, but not tight either. I had overlooked the inner lever the whole time. Cleaned, greased and sounds like it 's supposed to now..... quiet. Thanks for the help.
Yeah, that's the bolt that can come loose and leave you at the top of Lovers Leap in the mountains in Hillsville Va at 8:00 a.m. on a Sunday morning.
Check that one regularly.
Old 08-10-2012 | 06:26 AM
kyote's Avatar
kyote
Originally Posted by TUCCI
That's what I did also, check that rear shifter for the infamous spline striping problem that many are reporting. Make sure the tranny shaft splines are intact then replace the allen bolt with a hex bolt and torque it nice & tight. Don't get stuck away from home and if your getting too much play with either of the shift levers that's the first place I would be focusing on.
I need to do this for mine... What size is the bolt you used?? did you put a nut on the other side too? I was thinking that way it would really get pinched into the shaft..
Old 08-10-2012 | 11:31 AM
nchogfan's Avatar
nchogfan
Get an Ultra Classic with a batwing fairing instead of that Fugly!!!!! LOL!!!
And, is that Tammy in your avatar????
Old 08-11-2012 | 07:18 AM
katobird's Avatar
katobird
When I took mine out to clean and lube I installed an O ring on the shaft...
Nice and snug without any shifting effect
Old 08-11-2012 | 07:15 PM
FLoTR's Avatar
FLoTR
I think so >;-)
gja
07-01-2018 04:46 PM
Figstr
03-03-2012 10:27 PM
garcon
02-23-2011 07:55 PM
msbhvn
05-19-2009 08:34 AM
kkrommm
07-24-2008 06:40 AM
Quick Reply: shifter linkage
