Tall boy/Touring Pack
There is an inch of adjustment on the 09 and newer bikes, don't know about the older ones. I had to use a plate to move the tourpak back further so she has more room, now her calves hit the bag guards and I'm shopping for raised floor board mounts. I made my own adapter, but there are several available. The one from George Anderson looks good, and I almost went with it before I decided to do my own.
1. The tour pack has a small adjustment that can be made without any modifications, most of them I have seen are already adjusted all the way back but you might check yours;
2. You can buy a re-locator kit that will move it back up to two inches I believe; and
3. You can do it yourself by making a plate that bolts onto the rack and drilling new holes further back that match your tour pack hole (that avoids drilling into the tour pack plate). You can also drill the tour pack but on the standard set up you can't move it back much because there isn't much room to move the front hole forward (and therefore the pack rearward).
slyedog
Audio Systems
36
05-05-2017 12:00 PM
