88 twin cam motor A or B
The 88A engine is rubber mounted and is used on Touring models and Dyna models. The 88B engine is a counter balanced (2 chain driven counter weights inside engine) and is used on Softail models. Same holds true for the 96A and 96B as well as the 103A and the 103B engines.
I think they developed the "B" engine so they could set the engine lower on the Softails, but don't hold me to that because I'm no H-D designer. If you notice, the Softails all sit lower than Touring models. Also, the rear suspension on the Softail is horizontally mounted under the frame, not vertical on each of the rear wheel like a Dyna or Touring model.
I'm starting to ramble, so I'll shut up. Hope some of that helped.
Harrisondyna (03-04-2022)
