engine case vent mod - good bye oil in intake
seen this done on this forum off and on. basically got to thinking I do not want to suck in hot air into my intake, didn't want to suck in oil (I keep it low but it still sucks it in) etc, etc. So got a kit that was supposed to work on a twin cam...but it really wasn't designed for stage i intakes. so I put a metal cut off blade on my table saw and cut the case vent bolt barrels off my stage one back plate. used a little rubber to fill a small hole and mounted the kit up. I'm going to get a clamp to secure the end of the filter to one of the push rod tube lower cover base bolts. took it for a spin and I like it. I have an extra back plate if I decide I want to undo all this. The filter does get hot so there's definitely a lot of air movinging in and out. The kit I used was " 35-0123-VT Sifton Braided Hose Crankcase Breather Kit for 1993-up Harley Big Twin Evolution & Twin Cam 88 "
I upgraded to the new breathers in the rocker boxes and they are much better, less mist going thru intake. Then I decided I didn't want any oil going thru my engine so I changed to external breathers also. I keep a check on the hose ends and have very little mist going thru. I used braided line and AN fittings on mine with the SE heavy Breather.
I ran the hoses into a clear vented container the first 1k or so miles while I was deciding on what to do for a catch can. An oily residue around the walls of the container was all that was in there. After seeing that I had no reason to mount anything else.
No slick tires or oily mess under my bike and I do pre/post-ride inspections!
no oil mist since there is no vacum from the intake sucking oil out of the engine case. In this vent senerio, air moves in and out with each stroke of the pistons, the filter unit gets hot, but not wet at all from any oil. If there was an over fill senrio, the kit comes with a collector resivoir that attaches to the filter and collects over fill oil. so far, the filter is bone dry.
vhmike73
09-06-2014 05:42 PM
