Shifter shaft cover??
I know HD makes the shift shaft cover for people who remove the heel shifter and leave the toe shifter in the stock position. Does anyone make a shaft cover that would go on the inside of the shaft if the toe shifter was moved to the outside of the shaft? I had used several thick spacers when I did this with my 2010 RG, however I would like a more finished look on the new bike. Thanks
I had the Kuryakyn spacer but replaced it with a spring-loaded item sold by Soft Brake. Scroll down to the "Extended Spring-Loaded Spacer" (SB-ESS). I was getting quite a bit of shaking and rattling in the shifter area and this calmed it down considerably.
Bitchinbaggers sells one they're pretty proud of too.
http://bitchinbaggers.com/products/h...ft-eliminator/
I did this mod on my current and last bike.
I used this.
https://www.denniskirk.com/heel-shif...or.p573796.prd
It goes really well with my 1" Soos spacers and the position is nice.
While you're at it , remove the shifter shaft , drill and tap the primary bushing for 1/4x28 and install a grease fitting.
This combo looks good , works great , and has no play at 19,000 miles so far.
I must say , the Bitchin Bagger spacer looks nicer.
Mick
I used this.
Mick
