led turn signal problems
Old 07-08-2012 | 10:38 PM
dustyn2007's Avatar
dustyn2007
Default led turn signal problems
hi guys just installed led front and rear turn signals on my 03 road king put resistor on the rear but for some reason both turn signal indicators on dash stay lit any help would be great also the bike has the brake module that makes the turn signal also your brake light my buddy has the same setup on his 06 with no problems but he doesnt have security on his bike could this be my problem? thanks guys in advance
Old 07-09-2012 | 07:40 AM
bucket772's Avatar
bucket772
The brand of lights you are using would be helpful information.
Also if I'm not mistaken, depending on the brand of lights, you will need a resistor/load equalizer on both the front AND rear turn signal circuits. But that is only to fix the problem of the fast blinking. Also what kind of R/T/B module are you using? I would suspect a wiring problem in that unit if your dash lights are staying on. I just installed a Kuryakyn R/T/B on a VTX and the instructions were clear to state that the two ground wires need to be grounded to the chassis and not the negative side of the battery. Also the power to the unit is pulled from the running light circuit. You must not cut that wire, only tap into it.
Double check all the wiring and get a good meter to verify which wires do what. Test lights should not be used. There is no protection in the test light to prevent current from flowing into somewhere where it should be going. It's a real easy way to fry electronic circuits. Good meters will prevent this and will tell you exactly what is happening with the wire you are testing. Solder all connections and ensure that if you need a chassis ground that strip the paint down to bare metal or you'll never get a good ground.
Wade_W
07-09-2020 09:22 PM
malomj07
Electrical/Lighting/Alarm
05-20-2016 07:59 PM
scatgo
03-24-2016 10:17 PM
Mikula
02-15-2016 06:09 PM
dcloned
06-01-2013 07:53 PM
