acc switch what dose it do
Old 07-06-2012 | 05:26 PM
Firechaser1141's Avatar
Firechaser1141
Default acc switch what dose it do
ive got 2007 flhx as you all know there is a switch next to the ignition with acc on it i know about the plug under the seat but it dosent do noting to the plug and the plug is only a 3 pin not 4 pin like people say any ideas
Old 07-06-2012 | 05:34 PM
X Iron Butt's Avatar
X Iron Butt
On my 07 I have a Zepplin seat plugged into the grey plug under the seat. Not sure how many pins and there is another plug that is black. If the ACC switch is not down to the rear position (with the light in switch illuminated) the seat will not air up. Soooo the ACC switch powers up that grey plug in.
Good Luck
Old 07-06-2012 | 05:40 PM
Texas Fat Boy's Avatar
Texas Fat Boy
It connected to a plug under your seat, you can plug stuffinto.
So yours (like mine) doesn't do anything.
Old 07-06-2012 | 05:43 PM
Uncle Larry's Avatar
Uncle Larry
Received 49,997 Likes on 19,392 Posts
ACC Switch? .... Come on Brother! .... Automatic Climate Control !! ( sooner or later, it will be an option! )
Old 07-06-2012 | 06:58 PM
Geezer glider's Avatar
Geezer glider
automatic climate control,.....will only be offered as an accessary from MOCO to be purchased at the dealers like the plastic piece to align your tour-pack. Would likey be a fan that you can mount on your bars.
Old 07-06-2012 | 07:06 PM
TXCOMMISH's Avatar
TXCOMMISH
On mine? Nuddin....
Old 07-06-2012 | 08:30 PM
Harleypingman's Avatar
Harleypingman
The connector controlled by the ACC switch is a four-wire connector under the seat. From the factory, there is nothing connected to that connector so the switch controls nothing.
Carl
Old 07-06-2012 | 08:38 PM
Firechaser1141
Carl
mine only has three pins and i can check them with meter one is positive and two have nothing on them with switch on or off it dosent matter dont change nothing
Old 07-06-2012 | 09:01 PM
Irish Joe's Avatar
Irish Joe
I plugged a cigarette lighter hookup in it to charge my phone or i-pod. I can leave it locked in the saddlebag
Old 07-07-2012 | 04:59 PM
jimharvey1's Avatar
jimharvey1
No...it's a 4-pin. Orange, Orange-White. Red-Yellow and Black wires. Dig around a little bit more. Sometimes it can hide REALLY well.
Quick Reply: acc switch what dose it do
