Help! Front cylinder not firing...
2010 SG 96" motor, PCV w/autotune, and K&N air intake.
Out riding the other night, and bike started to run sluggish. Stopped at a family members house and started to play with the ignition wire. The front cylinder would catch here and there for a split second when I wiggled the spark plug wire at the ignition coil. So I figured bad spark plug wire. I made sure multiple times that it was on correctly and checked spark plugs.
Now after driving an hour and half to nearest dealership that had spark plug wires, still have the same issue. I also replaced the spark plugs.
I'm guessing its bad ignition coil, anyone have any suggestions?
Thank you
Josh
Thank you
Josh
sincityharley
Electrical/Lighting/Alarm
06-25-2017 01:55 PM
FXD_noob
11-14-2013 01:32 PM
