IDS bearing Failure
IDS bearing Failure
Well, today I started to change my tires (E3 with 24K still tread left but cupped badly) and much to my surprise I found the IDS bearing has failed. The inner races of this bearing move close to .100, which caused the sprocket to move inwards and rub on the bowl. What is interesting is that the sprocket must rotate approx a half an inch under power. This is evident by the wear marks on the back of the sprocket as it contacts the bowl. Trying to move the sprocket by hand shows no movement and the rubber blocks look good. Anyhow, this bearing made no noise whatsoever and I blame it on those damn long lasting E3 tires for not finding it sooner lol. New bearing and rubber blocks should put it back on the road.
Ride Safe!
Ride Safe!
This subject makes me paranoid but I haven't seen or heard any indication that my current bearing is in any way bad or failing, so I just keep on truckin' along with it. You know, "If it ain't broke...." It's now at 45k since installing IDS almost five years ago.
Originally Posted by mccstevie
The same bearing on my 08 Ultra failed with less than 14000 miles on it. Only noticed it because I could hear the ***** rattling while pulling in my garage.
Checked my service manual and found nothing on checking this particular bearing. There is a section on replacing it but the only thing they say about checking it is that you cant check its condition by spinning it, saying that since it is a split race bearing,it will feel rough if it is good or bad. This must have been a bad set-up from the get-go since replacement bearing I bought was a different design from what I took out.
Maybe being different is a good sign that the new one is better. I've always thought that the failures reported with '07's was because of faulty installation, but who knows. Some seem to last (like mine) and some not. IIRC the design of yours is the same except that you have a 25mm axle diameter and mine is 1.0", thus the bearing isn't interchangeable. From '09> the hub was integral to the wheel but I don't know what the bearing configuration is. I assume the axles are still 25mm.
I replaced the pulley bearings at the same time as I replaced my wheel bearings in my 09 RK. They weren't bad, just did it for piece of mind. Btw, in my pulley, I found that it is 2 bearings pushed into the same spot. Thought it was odd, but that was the waymy manual showed it and the way it came apart. So, if you don't have abs, order 6 wheel bearings and if you do, order 4 standard wheel bearings and 2 abs bearings.
Chris
Chris
I wonder if there's a spec on the bearing. I'm at almost 20k on my current E3 and it'll be due for replacement in about 2k, so I'll inspect the bearing at that time like I always do. I'll also look at the hub more closely, as I haven't paid any attention to it in the past except for the condition of the rubber bumpers. My gauge for a healthy bearing has always been no movement in the sprocket when fully assembled and no noise from the bearing. I always back out of my garage with engine off for that purpose, and I've never heard anything. Mine has always shown some movement in the lower race, but although I've never put a dial indicator on it I'm sure it wasn't anywhere near .100", which sounds very loose.
Since IDS was an accessory for the '07 there's nothing about them in my service manual. Yours was standard in your '08, so if you have a manual could you look and see if HD provides any guidance for checking the bearing?
