Clutch not grabbing anomaly...
Full tension in clutch handle, grab clutch, pull, shift into 1st, go to let clutch out, no grab - no go, pull clutch in, shift to 2nd, let clutch out, still no grab.
Turn handle bars to far right, grab clutch again, shift into 1st, clutch starts to work as normal.
So anyone have any clues, ideas, suggestions, on what the heck is going on? I just replaced the clutch cable on Monday, and everything was working just fine, 24 hours later this issue has reared its ugly head.
Not having any issues while riding and going through gears. Seems to only happen after a stop and shut off. Did the same thing to me this morning on a cold start as well.
TIA for any help.
TIA for any help.
Thanks for the replies even on the holidays!
Found the issue - new clutch cable is bad - it has separated from the pinch at the adjustment area causing the cable to stay retracted and causing the clutch to not engage. I will need to replace the cable, looks like I will need something a tad longer than stock as well.
I took the derby off and noticed that when I turn the steering in any one direction the plate moves, not good.
