Harley Part # 69200042A Review
I just installed the Harley part # 69200042A Tour-PakŪ Brake Light/Running Light/Turn Signal Conversion Kit
Turn signal module adds an auxiliary brake light and turn signal function to your Original Equipment Tour-PakŪ rear lighting. Red lenses glow when the headlamp is on, and increase in intensity when brakes or turn signals are activated. Easy-to-install, the kit simply plugs into your existing wiring harness
I will say its a nice plug n play harness that is fairly simple to install that gives you added visibility on the rear of your bike . But, if I would have known before hand that the 4 Way Emergency Flasher wouldn't flash the tourpak lights I would have not bought this wiring harness. It states that the flasher will work on the tour pak at the end of the installation instructions
I would have gone with the Ridetime Technologies Ultra turnz module that does incorporate the Tourpak lights to flash with the 4 Way Emergency Flasher
I would recommend the Ridetime Ultra Turnz module over the HD # 69200042A harness
Just added the CD LED turn signals, front and rear, tourpak LED's. Have the run/turn/brake module on order, back ordered, and it'll be here next week. Also doing the CD tourpak RTB kit which will be installed after I get their RTB module. Not sure which braking pattern I will use, but plan one that lights it up back there. Just activating the brakes and turn signals with the LEDs installed and being 20-30' behind the bike they are bright.
Chad..... Welcome to the forum...
Just FYI... You asked a question in an 8 year old thread.... you may not get an answer...
A couple posters have been on the forum recently... so it's possible....
FWIW... whenever I have a question after reading an older thread, I will usually create a new thread, posing the specific question, to get the most recent ideas/thoughts/info...
malomj07
Electrical/Lighting/Alarm
05-20-2016 06:59 PM
Fish Slapper
02-06-2008 09:11 PM
