Thinking about a King with a carb
If it's an older bike with the stock carb , go for it.
I bought my last bike 2006 FLHT because it had a carb and it was easy and inexpensive to tune.
At least a carb bike will generally make it home , even if it runs kinda bad , where an injected bike will need a tow.
The stock harley carbs are very easy to tune and the parts are available nearly everywhere.
Mick
Mick
It'll be a good deal,if the bike is ok.Check to see if the factory cover(the plug over the adjustment screw) is still on the carb. That way you'll know for sure if it's been gone into.If it's still their the bike is going to probley be lean in the fuel mixture.You can pop it off sometimes,or drill through it,just go slow when you get there you can adjust your carb.It'll make a world of difference,if you have experience doing so>.
