Oil in Airline?
Oil in Airline?
I tried to check the air in my suspension today and both fittings were filled with oil. I wouldn't think this is normal. Is it?
Rear seemed to have 15 psi and front had 10 psi. How can this be correct if i'm measuring oil? I haven't had this bike very long and still trying to figure it all out. I feel like the handling is very sloppy, but then again my most recent ride was a hardtailed Sporty.
Any help is appreciated. Thanks.
2001 EGC, 64K miles.
Sorry maybe I left out a few words but this quote means it is normal. HD instructions say this, don't know about other pump manufacturers.
"manufacturer will more than likely recomend pumping a little air in before you let any out to clear oil from the lines".
If you keep letting oil out it may result in low oil.
