Brake Lights Don't Work w/ Rear Brakes
Old 06-29-2012, 09:07 PM
Rock Chalk's Avatar
Rock Chalk
Rock Chalk is offline
Default Brake Lights Don't Work w/ Rear Brakes
Just realized tonight that my brakes lights aren't working with my rear brakes. When front brake is pulled, they all light up. Changes have been...added plasma rods last summer (brake only) and didn't have an issue, this winter took several pieces off for powdercoat including taking rear brake pedal off. Worked after that, not sure when it went out. Is there a separate switch for front and back I should look at? Or any ideas.
Thanks guys.
Old 06-29-2012, 10:21 PM
FLAMED96's Avatar
FLAMED96
FLAMED96 is offline
The brake lights work off of a presssure switch in the brake line. I would suggest checking the output of the pressure switch, when brake pedal is pushed line pressure increases and activates the switch. Easy inexpensive fix, just had mine replaced under warranty.
Old 06-29-2012, 10:28 PM
Dew Me's Avatar
Dew Me
Dew Me is offline
Did you buy it used? My '09 had a rear brake light switch recall. Got the notice in March maybe? Still haven't remembered to take it in for the recall. Check with the dealer or call Harley with your VIN ready to check it out.
Old 06-29-2012, 10:31 PM
pswomack's Avatar
pswomack
pswomack is offline
Take it to the dealer if it's 2009 or newer, there is a recall on the rear brake light switch, doesn't matter if you bought it new or used, they will fix it under the recall.
Old 06-29-2012, 10:50 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
There's a "brake light switch recall" where the hell have you been?
Old 06-29-2012, 10:54 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
No...the correct/polite question to OP would be - have you done the rear brake switch recall on your bike yet?
Old 06-29-2012, 10:55 PM
Rock Chalk's Avatar
Rock Chalk
guess i just always skipped reading that stuff since it doesn't sound too exciting, or a way to spend money ...i did do a search, must have not done it right.
thanks all.
Old 06-29-2012, 11:02 PM
Rock Chalk's Avatar
Rock Chalk
.....and shouldn't i have received something on this in the mail? (yes bought it new, '09 FLHX)
Old 06-29-2012, 11:15 PM
Devo6684's Avatar
Devo6684
Devo6684 is offline
A bad switch can also keep your brake light on and prevent the use of your cruise control. This is what happened to my RK. I did not find out if it can affect both your front and rear brake levers. My Indy fixed mine on my RK during a mod- it was a coincidence it went bad at the same time I scheduled my mods, otherwise I would of taken it to HD.
Old 06-29-2012, 11:23 PM
Texas Fat Boy
Nothing in the mail. I actualy fixed mine (2009 Street Glide) before the recall and had to ask to have my money refunded. It took a while but I got a refund.
Quick Reply: Brake Lights Don't Work w/ Rear Brakes
