xm antenna install for my 665
So, the install of my 665 is done to the point of mounting the GXM 40 hockey puck antenna. The bottom of the antenna has a thin rubber base. The antenna doesn't appear to be magnetic as it won't stick to the top of the radio. The provided two-sided tape won't stick to the rubber on the bottom of the antenna (not good enough for me to feel comfortable with it anyway) but likely will to the top of the radio.
What am I doing wrong? I see nothing more in the kit to use to mount it and the directions just say to mount it using the tape.
My 665 had an additional magnetic metal plate in the box that I screwed to the bottom of the antenna. I then set it on the radio. It hasn't moved in 5000 miles.
https://buy.garmin.com/shop/shop.do?pID=27341 $18 from Garmin, but I had one in the box.
Last edited by airchuk; 06-29-2012 at 05:12 PM. Reason: added link to magnetic base
No magnet plate in the box, just a ring of two sided tape that won't stick to the rubber bottom of the antenna. So I guess I'll need to figure a way to get it securely mounted with something else. I guess they didn't charge enough for the 665 to make the mounting foolproof.
I have the Garmin 665 not the Roadtech.
From Garmin's website -
What's in the Box:
What's in the Box:
- zūmo 665
- Preloaded City Navigator® NT for North America*
- Motorcycle mount with integrated power cable and mounting hardware
- GXM™ 40 antenna and magnetic base
- Carrying case
- Dust cover for motorcycle mount
- Battery pack
- Automotive suction cup mount**
- Automotive power cable
- USB cable
- Dashboard disk
- Quick start manual
What's in the Box:
What's in the Box:
- zūmo 665
- Carrying case
- Battery pack
- USB cable
- Dashboard disk
