Help me understand ABS brake lines
Old 06-28-2012 | 02:14 PM
gtrplyr's Avatar
gtrplyr
Default Help me understand ABS brake lines
I want to put taller bars on my 2012 FLHTP. I have ABS and will need a 4-6" longer brake line. I heard that I could simply replace the "upper" line, but then I heard that there was a "mid" line that also needed to be replaced. Can anyone please help me out?
Thanks!
Old 06-28-2012 | 04:49 PM
HandleBarLouie's Avatar
HandleBarLouie
you can get away with just a top line......
Old 06-28-2012 | 05:55 PM
vichendrix's Avatar
vichendrix
I just done my 2011 ultra has abs , stock line goes master to abs module one piece the new lines you will need are mid line which goes abs module to triple trees and then your top line which goes from the mid line to master
HTH vichendrix
Old 06-28-2012 | 06:00 PM
gtrplyr's Avatar
gtrplyr
HTH vichendrix
So I do need a mid line? Therefore two lines?
Old 06-28-2012 | 06:56 PM
Spur56's Avatar
Spur56
You only need the line from the master cylinder to the ABS module. Upper Line only
Old 06-28-2012 | 07:16 PM
vichendrix's Avatar
vichendrix
It depends on supplier i used magnum they use a 2 piece line if you ever change bars again bigger apes for instance you only have to order upper line than much cheaper later
HTH Vichendrix
Old 06-28-2012 | 07:32 PM
gtrplyr's Avatar
gtrplyr
HTH Vichendrix
Now that makes sense. Thanks, I was getting more confused with every post.
Old 06-28-2012 | 08:18 PM
vichendrix's Avatar
vichendrix
No problem enjoy the new bars i love mine the setup is perfect for me
Old 06-28-2012 | 09:11 PM
Potato_Potato's Avatar
Potato_Potato
I am confused & it seems like some posters are saying different things. When I did mine all I needed was the upper line that goes from the master cylinder to the manifold (splitter under the triple tree).
Old 06-28-2012 | 09:26 PM
Airborne350G's Avatar
Airborne350G
Does yours have ABS? On ABS bikes the lines go from the master cylinder to the ABS module, then to the spliter under the triple tree, then down to the calipers.
Quick Reply: Help me understand ABS brake lines
