120r running on one cylinder at idle, too hot?
It's not "Parade Mode".
It called "ENGINE TEMPERATURE IDLE MANAGEMENT SYSTEM" or "ETIMS"
When does it come on?:
When engine temperature reaches a pre-determined point, the EITMS will turn off the rear cylinder fuel injector. Idle speed will be maintained, however the rear cylinder will become an “air pump” which will work to cool the engine. EITMS will activate (rear cylinder will turn off) when all of the following conditions are met for approximately 6 seconds.
• Engine temperature is greater than 287° F domestic (165° C international)
• Twist grip opening less than 2.0%
• Vehicle speed under 1 MPH (2 KPH)
• Clutch lever in or transmission in neutral
When does it turn off?:
Engine speed under 1200 RPM EITMS will disable (rear cylinder will again fire) if any one of the following occurs:
• Engine temperature falls below 275° F domestic (135° C international)
• Twist grip opening greater than 2.3%
• Vehicle speed exceeds 2 MPH (3 KPH)
• Engine speed exceeds 1350 RPM
• Clutch is released with vehicle in gear When the engine is in EITMS mode you may notice a difference in idle cadence. Additionally there may be a unique exhaust odor. These are both considered to be normal conditions.
It's in the owners manual.
Engine Idle Temperature Management System
For those riders who frequently find themselves in riding conditions where the vehicle is subjected to prolonged idle conditions or traffic congestion, the motorcycle is equipped with an Engine Idle Temperature Management System (EITMS) to provide limited cooling of the rear cylinder.
When the engine is in EITMS operation, you may notice a difference in idle cadence. Additionally, there may be a unique exhaust odor. These are both considered to be normal conditions.
Vehicles are delivered from the factory with EITMS disabled. EITMS can be enabled or disabled by the rider using the following procedure.
Turn the ignition switch to the ON position (do not start the motorcycle).
Push the throttle to roll-off position and hold.
See Indicator Lamps: Touring Models. After approximately 3 seconds, the cruise indicator lamp will either flash green (EITMS enabled) or red (EITMS disabled).
Repeat the procedure as needed to enable or disable EITMS
I usually keep mine turned off, unless I get stuck in some serious traffic.
Usually never stopped long enough for it to do any good, and if you're in slow moving traffic, it doesn't come on.
It really seems kind of useless. Better off pulling over to the side of the road until traffic moves.
BTW....never had any pinging issues
there is a bucnh of misconception regarding the eitms. as the operator, you can not 'force' it to come on. all you can do is to enable or disable it. the rest is automatic, and dependent on a certain set of parameters (texas fat boys post).
i am interested in the quote from harley-performance.com. wondering where this information comes from as it seems to contradict hd's own literature.
So to be absolutely clear, EITMS works as in Texas Fat Boys post, the temp is the head temp (IIRC front cylinder head) and as skratch said, the EITMS detection mode can be forced off or on by throttle as in vzts4q's post, not double-twist as I remembered. This is on page 140 of the 2008 owners manual
neonhomer
05-18-2008 04:32 PM
