how do you clean the Idle Air Control 06 SG
have you tried some sea foam through the tank to start? Might help with your idle problem. It has on a few of my idle related issues on various vehicles. Good stuff
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
General Inquiries:
Phone:
775.331.3789
I am talking throttle body below.
The IAC is a solenoid step motor controlled passage around butterfly in throttle body. When the pintle valve open its the size of a pointed pencil and open up a large hole. This not your problem and if by chance it is the actual seat area, you can check that by simple removing air filter. Peer upward into top area of throttle body and key the switch on. You will see the pintle pull out all the way and come back to the high speed idle area depending on outside temperature and if engine is cold. Key it off and it jumps back all way in cutting off all idle air so you do not get run on with the high idle speeds ECM controlled bikes need so they do not stall. The ECM knows were it's at and if it really is bad it will tell you with an engine code on the dash. If it's off over +/-200RPM the code will set P0505 If it really is sticking someone has already stuck a carb/throttle body cleaner solution spray up in hole and drove crud up pass o-ring in solenoid and once it dries it jams and trashes it. From my experience at 40K that passage even with Harley venting the engine into the air box even that excess oil does not get into that passage sine it's at top of throttle body. (can get on butterfly and stick it but then what you need to do is spray a small amount on a clean lent free cloth and open throttle and reach in an wipe seat area and inside back face carefully till you no longer see crud. Never ever adjust it for idle.
I've used CRC MASS AIR FLOW SENSOR SPRAY CLEANER works good.
Check for an intake manifold leak. Spray WD-40 (or starting fluid) near the intakes by each head while idling. If the idle speed changes with spray you have an intake leak.
Four bucks for seals and 2.5 hours of labor with lots of cursing. I just finished and it fixed my idle issues, but what a PITA the throttle body screws are to get back on.
06 SG -- S&S T-111 motor
this only occurs while getting off the highway 70 - 80 mph to a stop, going to a stop bike idles fine then all of a sudden rpms drop from 1k to 6/700 then wants to cut off -- seconds later cuts off.
this has happened four times in the last two months; same circumstances.
bike re-starts just fine
