Motorcyclist terms...
Old 01-12-2007 | 09:47 PM
TexasRedneck's Avatar
TexasRedneck
Default Motorcyclist terms...
Stolen from another list without shame...[8D]
Tools that Bikers Use
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that
freshly-painted Fender you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and hard-earned
guitar calluses from fingers in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
Blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more dismal
your future becomes.
VISE-GRIPS: Generally used after pliers to further round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2 socket you've been searching for the last 15 minutes.
TWEEZERS: A tool for removing wood splinters and wire wheel wires from your
hands.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that inexplicably has
an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin," which
is not otherwise found under motorcycles at night. Health benefits aside,
it's main purpose is to consume 40-watt light bulbs at about the same rate
that 105-mm howitzer shells might be used during, say, the first few hours
of the Battle of the Bulge. More often dark than light, its name is somewhat
misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and
for opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips
screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power
plant 200 miles away and transforms it into compressed air that travels by
hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were
last over tightened 15 years ago by someone at the Motor Company and neatly
rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts not far from
the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well on
contents such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially
useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and
Old 01-12-2007 | 09:56 PM
Gordy 66's Avatar
Gordy 66
Default RE: Motorcyclist terms...
Geezes... I About Pissed my pants..That tool stuff is all true..I have personally used each one.
Old 01-12-2007 | 10:01 PM
FireHawk's Avatar
FireHawk
You been hiding in my garage?
Old 01-12-2007 | 10:05 PM
jimbo21165's Avatar
jimbo21165
ORIGINAL: Gordy 66
Totally agree!!!
Old 01-12-2007 | 10:06 PM
jimbo21165's Avatar
jimbo21165
especially the drill press....
Old 01-12-2007 | 10:09 PM
ILSRWY6's Avatar
ILSRWY6
Too Funny ... I can relate .....
Old 01-12-2007 | 10:10 PM
oley55's Avatar
oley55
[sm=yikesomg.gif]ain't it the truth. been there ands done every damn one of those. who's the genius that so aptly put those mental images to pen n' ink anyway?
Old 01-13-2007 | 12:28 AM
simidonb's Avatar
simidonb
Thanks, I needed that
Old 01-13-2007 | 12:37 AM
mjh's Avatar
mjh
That's cool. It would make my shop teacher cringe with fear.
Old 01-13-2007 | 05:53 PM
bonez's Avatar
bonez
lol hillartious
Quick Reply: Motorcyclist terms...
