ABS wheel bearings
ABS bearings are thicker than non, an abs wheel has one regular bearing and one ABS bearing on the sensor side, the thickness difference is made up at the sensor that takes the place of the standard spacer. What are you tring to do? Maybe I can help explain further
the abs brg has a reluctor plate in it not actually a plate, but small pieces of square metal, that is magnetized which the abs sensor reads wheel speed. I have a tool for checking the magnetic field, its a card with metal filings in it sealed in a window so you can see the patterns. you place the card over the brg, and you can tell if the abs portion of the brg is any good. its really quite simple but they are different and cannot be interchanged, as dpete said
I though that it had something to do with the censor. I replaced the ones in my sons 08 Dyna, the Harley shop said that they had a bad batch of them around that time. Thought I would try something different I used 2 SKF USA made 6205 bearings. Hum USA made bearings on a Harley now that's different!!!! The ones I looked at at the Harley shop came from three different countries and the US was not one of them. Well at least the bearing for the ABS wheels comes from Canada, but when I do my bagger I think I will still use a US made one on the side that doesn't take the ABS bearing, just saying. American parts on an American made bike, I like that!!
Or is it the sensor that has multiple pick-ups and just a single magnetic lug in the bearing?
I'm interested just for general information as to how many data points the sensor reads per wheel revolution.
I am not sure but I think they may be the same thickness, can't say for sure the ABS bearing that I look at at the shop had the 6205 number on it it was an *** brand bearing from Canada but one side had a different type seal, must be for the censor to work correctly. But I think all 6205 bearings are 25mm ID X 52mm OD and 15mm thick.
I don't know what the Harley shop would say if I pulled out my Mic out and measured it out at there counter LOL. But the regular bearings are 20 bucks and the ABS 30 bucks, so that ain't to bad. Thanks for all your input!!
Ride safe!!!
Ride safe!!!
Hey charlie, How many lugs (for lack of a better word) does the bearing have in it for the sensor to pick up? If you use the tool you described I imagine the shavings congregate the the magnetic lugs in the bearing and you could count them. Right?
