Adding oil through chain inspection hole?
yes, but you can better tell the correct level from the larger round cover ( "derby cover")
fluid level on this is not crucial, recent spec is: with bike upright and warmed up, if you can see fluid under the clutch basket, you are good to go.
with bike on stand you want the fluid to just cover the bottom of the clutch basket ( about 5/8" below the lip)
mike
mike
Yes, but you can't tell when you get the proper level. Oil should be added through the derby cover hole so you can observe when it's at the proper level. A factory manual will tell you how to check the level for YOUR bike.
mike
mike
Steve in Ct
Reason i'm asking is because i'm getting a drip from the drain screw, so i was going to drain the oil and reseal the screw and while i was at it i was going to adjust my chain, so thats why i just wanted re add my oil through the inspection hole. Just did my oil and it calls for 32oz and thats what i added
Steve in Ct
Steve in Ct
I have read (no personal first hand knowledge) that the bikes used by the police demo riders have extra oil in the primary because of all the clutch feathering done during the demonstrations. Conclusion: A little over servicing is not a problem.
If you are a stickler for "by the book" service the primary the old fashioned way and make sure it is correct. THEN, make a little dipstick from a coat hanger or any other material you like. Find and mark the point on the dipstick where the proper, just serviced level is. From now on you can check the level and/or service through the adjustment window.
