sag with stock air shocks
I've been reading a bunch about proper sag with air shocks (I have an RKC with 12" rear shocks) and realized that my shocks aren't sagging at all when I sit down!
I'm kind of short and every little bit helps, and apparently I had another 0.5"-1" that I didn't know I had. Maybe I'm not as heavy as the expected Harley rider, but it looks like I didn't get any sag until I let ALL the air out of the shocks. I weigh about 180 lbs and with no air in the shocks the bike felt like it actually settled down some when I sat on it...can I ride without any air in the shocks? I realize that it's not really "no air"...it's actually the same as atmospheric pressure so in theory there's still air in there to compress, but is it enough? I haven't had a chance to take it out with no air in the shocks yet but thought I'd get an answer first - I certainly wouldn't go riding around with deflated tires.
I will be replacing them eventually with something better...but trying to make the best of it for now.
It's not the air but the spring pre-load that determine sag. In other words, lighter riders should use shocks with less preload; heavier riders need more preload. Less load allows the shock's springs to react to smaller bumps. The spring's preload determines how much the entire shock sinks from the rider's weight. For the shocks to do its designed function, it must sag about 1/4 to 1/3 of its total travel. As an example, if the shocks have 3.5" of travel, it needs to sag about 0.75" to 1.0" when the rider settles into the saddle. The shocks needs to work both above and below its initial ride height. With no travel available at rebound from a bump, it will top out, suddently stop rebound damping and pitch the rider off the seat.
Location: Western Illinois, land of bad roads, and corrupt politicians
The sag on shocks should be about 1/3 or the total throw. In other words, if your shock has 3 inches of total throw, you should have around 1 inch of sag with you, and any luggage, and your passenger if you have one.
And the sag is the difference between the shocks fully extended on a lift, and with you and yours on the bike.
If you don't have enough sag, think about what happens when you hit a dip (tire goes down into the dip), and the shock has no DOWNWARD travel. The whole bike goes into the dip, and when you come out of the dip, the bike bottoms out.
But the shocks are designed for big folks. One size doesn't fit all. Shocks should be valved and sprung for your riding weight, and type of riding.
if you are considering making a change - STEP up and go with a fully automatic speed sensitive hydraulic suspension system - Drops you 2.5 inches at stop ( flat foot control) and raises back to factory height once above 13 MPH. As quite a few of the members can now attest - Its worth the money to buy the right suspension the first time.
Kilokato
2014-2023 Touring Models
33
05-17-2015 08:40 PM
