Got a code - P1353 Front Cylinder No Combustion EFI
Today I was out for a ride and for the first time, my check engine light came on and went off a number of times. when I got home and in to my garage, It was not lit.
I pulled the codes from the speedo and I got 1 code - P1353 Front Cylinder No Combustion EFI.
From my search I found that a loose plug nipple, bad wire or bad spark plug are the most common causes. I did find that my front cylinder plug nipple was un screwed about a 1/4 of a turn. I tightened it, and cleared my codes, and ran it about 20 miles or so. The code had not returned, but I noticed at start up, I had a miss or 3, but then it ran normal, and did not produce a light or code.
Should I be worried about the 1 time start up miss? anything else I should check out?
that 1st start up was prolly a re calbration of the ecu, I wouldn't sweat it
