Looking for direct connect amp...
As the thread title says, I am looking for a direct connect amp for my 02 Ultra. I have seen where hawg Wired has a two channel direct connect, but, I need a four channel. I have looked at the Bazooka option, but, their literature states it will not work on an 02 with built in CB; I have the CB. Does anyone else make a direct connect setup? I do not want to have to run speaker wires from the amp to all four speakers. I currently have my tour pak mounted with a quick disconnect and that is why I want to keep the stock wiring. Any suggestions appreciated!
Thanks,
Neil
RDMC
Thanks,
Neil
RDMC
I've heard the Kicker (Kuryakyn) amp first hand and it sounded pretty great to me. It is a 5 channel amp. It was certainly a huge upgrade from stock. He also had the kicker 6x9 bag-lid speakers and had upgraded the fairing speakers - This was on a SG. The 5th channel is intended to be for a sub. I believe they sell a 6" sub with enclosure for the saddle bag.
I don't mind running the power lines. I have looked at some of the amps that mention plug and play, but, they look like you still need to run their speaker wires to the speakers. There may be a simple plug into their amp, but I am looking for something like the Bazooka or the Hawg Wired that use the exitsing HD harness to power the speakers.
Neil
RDMC
Neil
RDMC
Neil
RDMC
Neil
RDMC
Carl
benson1603
Audio Systems
02-09-2019 01:54 PM
