anyone run a single front rotar ?
and how much cleaner and neater does the single rotor look ?
imo it looks a lot better with the big chrome cover on one side on your heritage
ill take a pic of my RKC tomorrow with one caliper on and one rotor if my back is ok to do so and see what you all think then
I look at it this way, I can't see how cool one rotor looks while I'l tooling down the road.... Hey man, it's your bike, I'm sure one rotor will stop it just fine. Just like when my wife mentioned my "thinning spot" on top of my head...I told her, "I hope it don't bother you, cuz I can't even see it".
wow, you can say that you don't put yourself in that position, I don't either, but other pr1cks on the road WILL put you in that position!
I agree that others may put you in a position that will cause you to brake suddenly. I do not ave ABS, my brakes as set up will lock up in turn my tires will skid. On my setup, my wheels will lock up the same as OEM setup. If the concern is that a single rotor will not stop the wheel from rotating I do not have that problem.
great job and the 13" rotor looks good too in chrome
wow and she looks stunning and there the wheels i were looking at buying for my RKC 06
Personaly I don't care what you do to your bike because its yours not mine. This forum is great to post questions to see what others have done that works and what doesn't work, but if you think HD's are junk buy something else.
Calipers are junk, shocks are junk, HK radios are junk, people talk alot of smack about how their HD's are junk and still keep buying them.
i never said HD is junk
i simply said that HD calipers and the breaking system they use on a stock Harley is rubbish
passes dummy back and says please be a good boy
jeeeez
