Max Pullback on 10" Paul Yaffe Monkey Bagger Bars
I'm about to pull the trigger on Paul Yaffe 10" Monkey Bagger Bars. I'm only 5'7" and hope to be able to tilt them back at least a little. I know I can't go far without hitting the tank on a full turn. Anyone know the max pullback you can get on these bars without hitting the tank? They're expensive and a big PITA if they don't work out. But I'm sure someone will take them off my hands.
Pictures would be great if you have em.
dave
dave
I'm 5'8 and had my bars close to the fairing when I first installed them for the look. But having a bad back I readjusted them back about three to four inches while I was sitting on the bike and re-tightened. Perfect for me now. You can pull them back pretty far without hitting anything, and I did have to go with a +4 on the clutch cable.
Before:
After:
Before:
After:
Thanks HL... I have them at approx 2" from the fairing, I could easily pull them back another inch... and if I still had the stock tank I could probably come back another 1.5"-2". They say with the 10" Monkey bars you don't need to change anything... however I wanted the black pearl braided cables anyway so I ordered a +2 clutch cable and a +2 brake line. Brake line is about perfect. Clutch cable is still to short... I can't route it how I would like and it has been pinched in the neck a couple times, I'm going to order a +6 clutch cable this weekend.
You really think someones going to say, "those bars look terrible in the position their in"...Put them in the position that's comfortable for you, who gives a rats *** what others say!!!!!
