Rear Shock oil help
Use Amsoil 10w Shock Therapy for pre 09s
I liked the heavier fluid in my pre 09 shocks when I changed the fluid and the lighter in my -09's...
the fluid's weight does make a difference as well as the amount of fluid
I was trying to achieve the ideal balance of fluid while using little to no air to achieve the ride I so prefered...
depending on your weight will dictate how much fluid you use
Yes the fluids we use are the fork fluids
I believe belray is one of the few that offers a shock specific fluid
I prefered the Torqco 7.5 wt. brand in my pre 09's and the spectra very light in my 09
FFT
paul
FFT
paul
Amsoil is just another brand the guys are working with
Pretty much any fluid will help and improve the ride
But one of the most important steps is the amount of fluid is in there
because 10.8 came out does not mean 10.8 has to go back in
you can put 9.8 or 11.8
It spends on your preference
I always figured a rider wanted to get a sweet ride first with air and oil first then start adding more fluid to control the reduction in air so its not so air controlled specific
Its real easy to remove fluid and to add fluid if needed...
It ain't rocket science
Pull up my post I did some many years ago on Making Stock shocks better
A buddy was speaking with a well know man in the industry and what he said made sense
he said to make a huge transformation in the rear factory shocks is to add 30# motor oil to them...The frothing is non existant with motor as with other fluids
Thats the last thing you want is the fluid to co-mingle and start foaming with your fluid
Defeats your purpose
again FFT
Paul
Fork fluid will work
again FFT
Paul
again FFT
Paul
Jason
