ProCharger Ordered
#42
I got the primary side finished today. I ran into a slight issue, the installation manual is precise in some areas and vague in others (i.e compensator). I had to stop due to the fact I was "sweating my ***** off", 100+ here in Philly. Also, come to find out my SE 58MM Throttle Body will need to be drilled & tapped, due to the fact there's no where to grab a vacuum from. Sorry, but I had no time to take pics. Gonna try to work on the intake side tomorrw until it starts to heat up again.
#43
The cam that comes with the 120r is ok for the blower it is not the best but will work very well. We have are Dragos 656 blower cam that bolts right in. And makes big numbers...........
I will call you later to see how things are going.
Enjoy the power its fun....
Thank you for the info and help i called you this week from Michigan and am ready to order when you get time too call me back , 989-859-7428
Thanks again for all the info on the procharger for my 120R
Fred
#44
