Those who know about/had SE compensating sprocket failures, please help!
I wonder if there are any other alternatives to the SE comp out there.
I went the more traditional modifications on my comp and now have about 30,000 miles on it with no problems. The flat faces of the comp sprocket almost make a seal with the opposing faces keeping oil out of where it needs to be. I used a Dremel and put a radial slot the the base of each spoke on the smooth face on both sides of the sprocket and connected one slot on the front with the next adjacent slot on the back with spiral groves. There are three spiral groves in the inside of the sprocket journal connecting each slot on the front side with the next adjacent slot on the back side. That seems to minimize or eliminate the fretting on the sprocket hub.
Where the cam and sprocket spokes interface I also made radial grooves on each spoke starting from slightly inside (nearer the hub) to about HALF WAY through the wear area on the spoke. Hopefully that allows oil to sling centrifugally into the interface but NOT out the other side keeping the oil where it needs to be.
This is purely "shade tree engineering" and done free hand and I have only my own experience to pass on. So far so good. This required no sheet metal fabrication, brazing or machining the high tips off the cam piece. With the spring pack these comps have, I doubt that the reduced cam depth would ever cause a slippage problem. I hope it doesn't take the MOCO another 8 to 10 years to work out a professionally engineered fix. Compared to the previous, weaker comp this one really does the job. It just wasn't quite "finished" by the time it was put on the market.
Thanks
wethead103
2014-2023 Touring Models
34
11-28-2018 07:11 AM
