Do I really need to buy an HD air pump for air shocks?
Old 06-13-2012 | 02:08 AM
benjamin247's Avatar
benjamin247
Default Do I really need to buy an HD air pump for air shocks?
I just bought some air shocks (on the way) from a Road King. Do I need to buy an HD air pump or will handpumps used to pump bicycle tires work (with PSI gauge)?
Old 06-13-2012 | 02:10 AM
mike5511's Avatar
mike5511
Yes, bicycle pumps work just fine.
Old 06-13-2012 | 02:36 AM
blackflame's Avatar
blackflame
How do you keep it from leaking as you disconnect the pump?
Steve in Ct
Old 06-13-2012 | 02:51 AM
mkguitar's Avatar
mkguitar
hold up- the pump needs to be a VERY small bore.
MOST bicycle pumps will overpressure the system in less than one stroke--- blowing the seals out-$$$$$
the "syringe" type pump sold by HD and other vendors is perfect for air shocks.
pricey, but perfect.
Mike
Old 06-13-2012 | 02:52 AM
last12know's Avatar
last12know
Mike
+1 will save you damage
Old 06-13-2012 | 04:53 AM
harfooz's Avatar
harfooz
A bicycle fork pump will do the trick for you, and is often available at bicycle shops at a lot lower cost than the HD model. Many mountain bike forks come with a syringe style fork pump in the box, so check at the local mountain bike shops to ask for one. You can also get them off nashbar.com, performancebike.com, and so forth for a lot less than the HD brand specific model of the same thing.
Don't use a bicycle tire pump! Make sure it's a syringe style pump made for forks and you'll be fine.
Hope this helps,
'fooz
Old 06-13-2012 | 04:58 AM
luc.who's Avatar
luc.who
Look for one in the fs section. I keep mine in my saddle bag so I can check them when we are out riding.
Old 06-13-2012 | 05:53 AM
Challenger's Avatar
Challenger
Looks like you dumped $600 into pipes and you wont spend $50 on a hand pump?
Old 06-13-2012 | 06:01 AM
aviaator's Avatar
aviaator
I use my shop air compressor and put whatever psi I want in a portable air bottle, then use the air bottle to "fill" the shocks. No blowouts but the downside is it's not portable so have to borrow a bud's pump for checking/filling on longer trips.
Old 06-13-2012 | 07:12 AM
Ronp42's Avatar
Ronp42
Account Retired
The HD shock air pump or simular is worth every penny. It's easy to get the exact PSI you want and doesn't lose any when disconnecting. I changed the oil in my stock shocks to 10 wt and only run 10 lbs riding solo.
Quick Reply: Do I really need to buy an HD air pump for air shocks?
