Changing Grips Question
Old 06-12-2012, 12:07 PM
WestPalmBop's Avatar
WestPalmBop
WestPalmBop is offline
Default Changing Grips Question
Changed the grips last night. Everything seems to go on fine but the throttle grip will move just a little bit side to side now. Not sure if it used to do that and I just noticed or if it is a new issue. Everything is tightened back up and torqued.
Anyone else have the same issue?
Old 06-12-2012, 01:07 PM
CWO USN's Avatar
CWO USN
CWO USN is offline
Throttle grips slides out with very little persuation unlike clutch side which usually have some glue of sorts that keep it on tightly. My throttle grips doesn't move any at all but I can pull it off easily.
Old 06-12-2012, 01:13 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
The HD aftermarket grips go on snugly, but I have heard that several other brands have a bit of play on the throttle side. I went for the HD.
Old 06-12-2012, 01:20 PM
jg4660's Avatar
jg4660
jg4660 is offline
My stock 12 RK throttle grip has play side to side.
JG
Old 06-12-2012, 01:33 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Its supposed to have a little play, it twists around the 1" bar if its too tight it will hang up then youll have other issues.
Old 06-12-2012, 02:36 PM
rwtrick's Avatar
rwtrick
rwtrick is offline
I have the stock grips on my RKC and I have a little play in my throttle grip. It's always been there - thought it was normal.
Old 06-12-2012, 03:22 PM
WestPalmBop
Ok sounds like it's normal. They are HD grips, not aftermarket. The play is only side to side and very slight.
Old 06-12-2012, 03:39 PM
Str33tgl1de's Avatar
Str33tgl1de
Str33tgl1de is offline
i'm going to be tackling my grips this weekend any suggestions on what to be careful with?
Old 06-12-2012, 04:49 PM
WestPalmBop
It is really easy. Will need a knife to cut off the clutch grip and a torque wrench to put them back together. Takes 10 minutes total max.
Quicknick
02-22-2012 11:33 AM
jhix
10-01-2011 12:35 PM
RocketRocker
12-15-2009 11:42 AM
kelton3
09-25-2008 02:05 PM
rmarion
12-02-2006 04:24 PM
Quick Reply: Changing Grips Question
