Replacing adj. rider backrest pivot assembly
Stock adjustable backrest pivot bracket assembly for 2006 FLHTCUI was tweeked by previous owner. Original has flexible receiver clip with horizontal dual prongs that retain the backrest post. Tried to replace with stock part as per HD, but received pivot assembly with welded receiver clip and single hole for backrest post! Unusable with my backrest! So do I have to replace the entire backrest assembly, just the backrest, or is there another pivot bracket assembly that I need (ordered/recd. 52342-09)?
I know this is an old post, but did you guys by any chance made it work?
I just purchased a new backrest, but this backrest doesn't have the dual prongs on the shaft. Is it possible just to swap out to the new pivot bracket to allow me to but in the new backrest in there without replacing the whole assembly?
Pivot bracket repair kit (includes pivot bracket, lever, spring and hardware)
52342-09
52342-09
Mach1diesel
09-11-2017 09:10 PM
