Cams & heads or 107
Old 06-11-2012 | 01:46 PM
nevada72's Avatar
nevada72
Originally Posted by CigarCritic
Now I'm running Level B heads and have even more power.
What are your numbers with the level B heads?
Old 06-11-2012 | 02:27 PM
CigarCritic's Avatar
CigarCritic
No idea. I'm taking off the 4" Rineharts and installing Bub 7's tomorrow. I'll get some new numbers after Autotune dials the pipes in.
Keep in mind, higher compression encourages detonation/pinging. I'm able to control pinging with my current build. In the past, I've gone with higher compression and could not stop pinging.
Old 06-11-2012 | 03:10 PM
vduzin12's Avatar
vduzin12
Originally Posted by boogaloodude
I tore down my 103 last winter and built a 107 at 10.75 compression, woods tw8 cams. I was starting with a factory 103 at stock (9.6) compression. I wanted to raise compression in some way, and in every case, it involves pulling the heads. (mill the heads for samller chambers, go to higher compression 103 pistons, or going with a 107 build).
Once the heads are off the motor, it's only another 45 minutes or so to swap in new pistons and jugs, so lots of guys figure that's the best time to build a bigger motor. If you were starting from 96, you might have more incentive, but there's still lots of gains to be made by building a 103 out to 107.
Did you have any pinging issues with 10.75 compression? Also, what octane gas are you running, 91 or 93?
stal94gt
Engine Mechanical Topics
03-14-2018 05:40 AM
InthewindMN
13
11-10-2016 10:55 AM
Improved700
08-06-2014 07:01 AM
Sallyman
03-21-2011 08:14 AM
jshull
Exhaust System Topics
11
12-27-2010 10:58 AM
Quick Reply: Cams & heads or 107
