Deceleration Popping
Old 06-08-2012, 10:04 AM
JJHOG's Avatar
JJHOG
JJHOG is offline
Default Deceleration Popping
What does popping on deceleration usually an indication of? I've recently had my bike Dyno Tuned.
Old 06-08-2012, 10:10 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
If its been tuned dont worry about it theres always going to be some decel popping. If its extreme then I would have it checked.
Old 06-08-2012, 10:24 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
My bike's dyno tuned and doesn't pop at any time. Have a chat with your tuner.
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
Decel pop is caused by either a too lean condition at 0% throttle or an exhaust gasket leak causing unburned exhaust gasses to combust in the pipes.
If you just got it tuned it may need some fuel added @ 0% throttle,that's if it didn't pop before the tune. Mine popped on decel so I added 5% fuel and problem solved.
ubreal (05-02-2019)
Old 06-08-2012, 10:26 AM
TheArchitect's Avatar
TheArchitect
TheArchitect is offline
From this thread:
From the TTS Manual (this is the first thing to try) - The SERT is the earlier version and this still applies -
DE fuel is controlled by the Decel Enleanment Multiplier table, Figure 3-25. The intent of this table is to temporarily remove fuel when the throttle is closed. DE mode is terminated if the throttle is opened more than about 3 percent. Note that larger multiplier values remove more fuel, just the opposite of the AE table!
This table affects exhaust “popping” when backing off the throttle. Typically, popping occurs because the mixture is too lean. Setting the multiplier value lower will richen the mixture and may help this condition.
Edit to add- I assume you mean it was not popping before the tune and started popping after the tune, in which case the tune may need some tweaking. If you added new exhaust at the same time though you may have an exhaust leak. Exhaust leaks will cause the same popping issue.
Old 06-08-2012, 10:32 AM
criyi's Avatar
criyi
criyi is offline
lean huh...maybe that's why I get a loud backfire every once in awhile after installing the Arlen Ness Stage 1 and the V/H twin slash 2 into 1.
Old 06-08-2012, 11:43 AM
Harleydaddy's Avatar
Harleydaddy
Harleydaddy is offline
I just put Rush Big Louie slip ons on my RK and have the stock football a/c and am getting some decel popping and backfiring. No tune at this point. Getting that done next week. Hopefully the tune will eliminate this.
Old 06-08-2012, 12:06 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
That's what I did to solve my popping on decel.
Old 06-08-2012, 12:07 PM
Keeper01's Avatar
Keeper01
Keeper01 is offline
What pipes are you running? I know that with all the Thunderheaders I've run, they pop a little on decel, even when they bike has been perfectly dyno tuned.
Old 06-08-2012, 03:48 PM
JJHOG's Avatar
JJHOG
JJHOG is offline
V & H regular Ovals with V & H Power Duals.
Quick Reply: Deceleration Popping
