HD Circulator seat pads
06-08-2012, 07:04 AM
Just want to report that recently I purchased and started using HDs circulator seat and backrest pads. They really work as advertised. 130 miles on a mid 90s day and at the end my butt and back were not wet. Just wanted to throw this out there as summer heats up and some of you may be wondering if they are worth the price....yes.
06-08-2012, 07:07 AM
Works yes... boughtr mine generic from another vendor...$50.00
06-08-2012, 08:10 AM
I purchased the pad prior to a recently completed 1500 mile ride and it worked fine. The pad gives you the airflow down below and does not raise your height in the seat. The pad has a strap that slips over the nose of your seat. Worked great! SJ Ron
06-08-2012, 08:24 AM
Quote:
Originally Posted by
Notgrownup
Care to elaborate a little more ?
06-08-2012, 08:32 AM
They do work great, and when you stop somewhere for a break your seat isn't 150 degrees when you go to sit back down either.
If you combine it with some compression shorts it's even better.
06-08-2012, 04:55 PM
I refused to buy one, so my wife decided to buy one for my birthday, one of the best birthday gifts I ever received, it really works, I love it.
06-08-2012, 04:58 PM
I bought one and they work great.
06-08-2012, 07:20 PM
Notgrownup
I bow to you King Circulator!!!!
06-08-2012, 09:13 PM
Texas Fat Boy
OK, I am going to show my ignorance! What the hell are compression shorts?!?!?!
06-08-2012, 09:24 PM
Challenger
Actually the ld comfort shorts are the best I have found. They really reduce extra moisture, no seams and reduced pressure points.
http://www.ldcomfort.com/
Compression shorts are the tight Lycra type shorts you see in many athletic events
