Accessory Auxilary Switch Activation ?
Folks,
I have a 2011 Road King. I want to know when the Accessory Switch will turn on power to my accessory when I flip it up. Is it 1.) When the switch on the console is turned to ACC? 2.) When the switch on the console is turned to Ignition with engine off? 3.) Only when the engine is running? One, two or three or a combination as a response works.
I already know about the plug under the seat so no need to point that out. I also think the numbers on the plug have 3 as the wire activated when the accessory switch is turned on and 4 as the ground.
Thanks in advance for your response.
John
John
On my 09 Ultra, as long as the ignition is turned on (engine does not have to be running), the accessory switch will work. Turn off the ignition, and it will shut off the accessory. The other wires work great for adding extra lighting. There are 4 wires coming out, 1 is ground, 1 is controlled by the ACC switch, 1 is brake, 1 is running lights. I have used this plug for adding extra brake and running lights so i didn't have to butcher any existing wiring.
I have a heated hammock seat that plugs into the accessory plug. It is connected to pin 3 for power and uses pin 4 to ground; therefore, power to it is controlled by the accessory switch on the nacelle. I also connect a riser mounted radio to switched power, pin 1 of the accessory plug--which has power when ignition switch is either ON or ACC and it not controlled by the accessory switch on the nacelle.
simplified summary (I hope):
12vdc (switched/P&A circuit) --> accessory plug pin 1
12vdc (switched/P&A circuit) -->accessory switch on nacelle --> accessory plug pin 3 (+) --> [accessory] --> accessory plug pin 4 (GND)
That diagram is for older models. The more recent colors are different. Pin 1 wire isn't green anymore. It's orange with red. Pin 2 wire is red and yellow instead of red and white. The other colors are the same.
