Accessory Auxilary Switch Activation ?
Old 06-09-2012, 10:02 PM
cafjo01's Avatar
cafjo01
cafjo01 is offline
6th Gear
Thanks for all your replies. They were most helpful. I needed that information in order to wire my Roadtech XM radio to the accessory plug. I wanted to test it out without using the ignition switch which primes the fuel pump. After some initial wiring and testing with the ACC switched on, I was able to pull the fuel tank without pulling fuses and such, in order to run the wires in the channel on the frame. Eveything works great now.
Thanks again,
John
Fxdbi-06
Electrical/Lighting/Alarm
03-22-2018 07:29 PM
streetleon
06-21-2012 02:45 PM
Mal74
03-23-2011 09:30 PM
HOGNOT
05-15-2010 02:41 PM
markuhen
07-04-2006 06:11 PM
Quick Reply: Accessory Auxilary Switch Activation ?
