Clutch cable ran out of adjustment? What gives?
Hi All,
I installed an AIM clutch kit with a 340lb spring and a Barnett clutch cable. Everything works great but I have a bit too much free play at the lever. I went to adjust the clutch cable to take up some of the slack and the threaded end popped out of the adjustment nut. I'll assume there is no other place to take up the slack in the lever? Any other ideas? I don't like having 1 thread in the adjustment barrel.
Thanks,
J.
Thanks,
J.
WVHARLEEMANN (03-17-2022)
Boomer1143 (05-06-2023)
Yep, I believe only backing off a half turn instead of 3/4 turn should take up some slack for you. It took me a few tries to get the feel for adjusting it at the clutch pack. "Lightly seated" is different to everybody, for me I'd watch the clutch diaphragm to see when it just barely started to depress, backed it off a very, very slight amount, and then a little over a half turn from there.
You'll know it's finally correctly adjusted at both ends when the freeplay is right and the clutch disengages where you want it to using the clutch lever. I like mine a little closer to the bar, so it disengages about an inch off the handlebar grip. If it disengages immediately when you touch the clutch lever, you went too far- it's too tight at the clutch pack and you'll risk burning up the clutch if you ride with it like that for too long.
Did you use a new cable or the old one cuz I tried that and it didnt work....you ran out of threads cuz the G__d__m cable stretched at least thats what happened to mine, playing with clutchpack screw just partially engages the clutch. Your just going to have to take the adjuster as far as it will go without it running out of thread and lock it down. It will just have to do or change to a new clutch cable. If you used a new cable you need to make sure its got a max 3 1/2" pull.
Sc0- (05-06-2023)
Sounds like you may have a defectivily made cable (if its new). I just purchased Barnett clutch and throttles and the throttle cables had too long of a "travel length". Barnett sent me a universal adjustable end which I had to cut some cable off to get them to adjust. You wont be able to do that with the clutch, but I noticed the clutch cable has a pretty long adjustment to it for a new cable.
Now I am thinking Barnett has some QC issues.
